Re: [Nagios-devel] Orphan hosts in hostgroup list
--========GMX275081218390453434100
Content-Type: text/plain; charset="iso-8859-1"
Content-Transfer-Encoding: 8bit
> For extra points, make it not create the host/servicegroups if they aren't
> going to be displayed.
I've done some improvements. The groups are only created for the CGIs if the config variables are set to 1. So now I've earned the extra points :) Just kidding...
> Ethan, these patches look simple enough that it's worth applying imo. It's
> also something some people have expressed wishes for. The default should
> probably be to not show them though, and to not create them when they're
> not to be shown. I can fix that later if you like.
The default is: they are not created in the main Nagios program.
And the default for the CGIs is: they aren't created (and thus shown).
If you like to apply them I've added extra parts for the config and html files, too.
And now I know how to create one diff file for all changed files with cvs. By the way, is there an approach replacing cvs by subversion?
Regards
Bernd
Der GMX SmartSurfer hilft bis zu 70% Ihrer Onlinekosten zu sparen!
Ideal für Modem und ISDN: http://www.gmx.net/de/go/smartsurfer
Content-Type: application/octet-stream; name="orphan_hosts.diff"
Content-Disposition: attachment; filename="orphan_hosts.diff"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...[email truncated]...
