Would it be much work to change the config file syntax to XML instead of
the current 'define XX { option value }'. Even adding an option to use
XML for configfiles would be great.
Changing the syntax, or adding an option to use XML config files would
make it easier (at least for me
them in various (PHP) scripts.
Currently I use 'fancy' regexp's to parse the configfile and a nagios
specific function to write the files.
Regards,
Dennis Roos
