This is where a good portion of the problems appear when something goes
wrong and needs to be debugged?
I think it would be a grand idea make the parent process prove stderr
diagnostics if stdout has nothing to say.
As an aside, is there a way I can get involved in the 3.x series
discussions/development? If nothing else, I'd sure like to see what's
coming around the corner and perhaps help out...
Bob
> Thomas Sluyter wrote:
>> On 25 Oct, 2006, at 0:08, [email protected] wrote:
>>> But being a lazy programmer, I am thinking, why not just have
>>> Nagios be a
>>> little more forgiving and inquisitive and keep searching stdout
>>> until it
>>> finds the first non-empty line? Is that so bad? Or is it a feature?
>> You'll like Nagios 3 when it comes out. It'll allow you to read
>> multiple lines of stdout. So be patient, little grasshopper.
>> Cheers! o/
>> Thomas
> As Thomas mentioned, Nagios 3 will support multiple lines of output from
> plugins, so this patch would break that future feature.
> any output after the first line will get thrown into either the
> $LONGSERVICEOUTPUT$ or $LONGHOSTOUTPUT$ macros, depending on what type
> of check was performed. There is also a 4K or 8K limit on the output
> size to prevent runaway plugins from returning too much data.
> Ethan Galstad,
> Nagios Developer
> Email: [email protected]
> Website: http://www.nagios.org
> Using Tomcat but need to do more? Need to support web services, security?
> Get stuff done quickly with pre-integrated technology to make your job
> easier
> Download IBM WebSphere Application Server v.1.0.1 based on Apache Geronimo
> http://sel.as-us.falkag.net/sel?cmd=lnk ... dat=121642
> Nagios-devel mailing list
> [email protected]
