Re: [Nagios-devel] Update API memory leak
On 03/29/2011 07:57 AM, Matthieu Kermagoret wrote:
> On Fri, Mar 11, 2011 at 3:09 PM, Matthieu Kermagoret
> wrote:
>> Attached patch fix a leak that occurs each time Nagios checks for an
>> update on api.nagios.org .
>> What do you think about it ?
> Any committer around interested in fixing memory leaks in Nagios Core
> ? At least a comment (positive or not) on the patch would be great.
I would take this, but I haven't had time to get an svn-import of
Nagios up and running properly yet so I have nowhere to stash it.
OP5 AB www.op5.se
on peace.
