This is a multi-part message in MIME format...
------------=_1099523855-32819-97
Content-Disposition: inline
Dear Folks,
I am writing to thank you for your letter and say,
On Wed, Nov 03, 2004 at 11:03:49AM +0000, Matthew Kent wrote:
> On Wed, 2004-11-03 at 17:08, Justin Lambert wrote:
.. prob report and sensible advice snipped.
> Beyond that, initially I had very little luck getting embedded perl to
work on my RedHat 7.3 install with nagios 2.0, unless you need it.
> I'd remove --enable-embedded-perl and --with-perlcache.
Unfortunately I concur.
The 2.0a nagios embedded Perl has some mistakes in it that prevent it's
use on other than old Perls (ie Perl 5
> Best of luck,
> Matthew Kent
> http://magoazul.com
Yours sincerely.
Stanley Hopcroft
Network specialist, IT Infrastructure
IP Australia
Ph: (02) 6283 3189 Fax: (02) 6281 1353
PO Box 200 Woden ACT 2606
http://www.ipaustralia.gov.au
Content-Type: text/plain; name="disclaimer.txt"
Content-Disposition: inline; filename="disclaimer.txt"
MIME-Version: 1.0
X-Mailer: MIME-tools 5.411 (Entity 5.404)
This message contains privileged and confidential information only
for use by the intended recipient. If you are not the intended
recipient of this message, you must not disseminate, copy or use
it in any manner. If you have received this message in error,
please advise the sender by reply e-mail. Please ensure all
e-mail attachments are scanned for viruses prior to opening or
using.
------------=_1099523855-32819-97--
