[Nagios-devel] PHP user interface for Nagios
About the authentication, I am not currently using the httpasswd =
mechanism I am using a NTLM module to authenticate against an Active =
Directory, should this still work with your code?
-----Original Message-----
From: Jes=FAs M. NAVARRO [mailto:[email protected]]=20
Sent: Monday, June 02, 2003 2:51 PM
To: [email protected]
Subject: [Nagios-devel] PHP user interface for Nagios
Hi, list:
I've been hacking some PHP files for a Nagios UI. I read what's about =
PHP=20
from the Nagios developer team perspective (that is; it would be nice, =
but=20
it's not high in their todo list) so I designed this as a fast drop-in=20
replacement for what's already there.
Major characteristics:
* GPL (of course, while I still haven't included GPL notices within =
source=20
files).
* "Proper" authentication through sessions (it uses Apache files from =
htpasswd=20
and reads roles from the cgi.cfg nagios' file).
* Themes support (through the use of Smarty templates).
* No need of cgi support (it includes php wrappers which call in turn =
the cgi=20
executables through system calls) nor cgi rewriting (the php files use =
cgi=20
extension so hardcoded links within the cgis point to the correct =
locations).
What is still not there?
* The wrappers for CGIs that embed figures (like statusmap.cgi and some=20
reports) don't work yet.
* The wrappers for CGIs that use both GET and POST variables (notably =
cmd.cgi)=20
don't work either.
What do I want to achieve?
* End up with fully separated functionallity from nagios "core" (the =
engine=20
and plugins) and nagios-ui (the user interface).
* Fully themeable and multi-language support.
* Easy to deploy environment (so it's easy for everyone to modify ui to =
their=20
own needs through themes and/or new php code).
You can find it at http://www.undominio.net/nagios_ui/index.html
I'd want to know about your feedback and opinions.
TIA.
--=20
SALUD,
Jes=FAs
[email protected]
This SF.net email is sponsored by: eBay
Get office equipment for less on eBay!
http://adfarm.mediaplex.com/ad/ck/711-11697-6916-5
_______________________________________________
Nagios-devel mailing list
[email protected]
https://lists.sourceforge.net/lists/lis ... gios-devel
Original poster: es=FAs M. NAVARRO [mailto:[email protected]]=2
