--------------080708080400040000010703
Content-Type: text/plain; charset=ISO-8859-1
On 08/25/2010 01:58 PM, Jochen Bern wrote:
> On 08/24/2010 11:30 PM, Jochen Bern wrote:
>> I wrote a patch for config.c which makes the links display the
>> appropriate "expansion" right away.
> Update:
2nd update (sorry for the spamming :-C ) ...
-- Removed a blob of superseded code
-- Changed the "(undefined/empty)" non(!)-error from #F00 to #00F
-- Explicit message when command_name is undefined
-- Text input field to enter/modify the command on the fly, hence ...
-- ... now listed in top right for direct access, too
-- For all other modes, added an to the to manually
narrow down the listings
Kind regards,
J. Bern
--=20
7
Unternehmenssitz Weiterstadt, Gesch=E4ftsf=FChrer Metin Dogan, Oliver Mic=
hel
name="nagios-3.2.1-CommandExpand-patch.txt"
filename="nagios-3.2.1-CommandExpand-patch.txt"
--- config.c.orig 2009-05-15 16:02:47.000000000 +0200
+++ config.c 2010-08-26 14:43:09.000000000 +0200
@@ -65,6 +65,7 @@
#define DISPLAY_HOSTDEPENDENCIES 11
#define DISPLAY_HOSTESCALATIONS 12
#define DISPLAY_SERVICEGROUPS 15
+#define DISPLAY_COMMAND_EXPANSION 16211
void document_header(int);
void document_footer(void);
@@ -84,6 +85,7 @@
void display_serviceescalations(void);
void display_hostdependencies(void);
void display_hostescalations(void);
+void display_command_expansion(void);
void unauthorized_message(void);
@@ -91,9 +93,24 @@
authdata current_authdata;
int display_type=DISPLAY_NONE;
+char to_expand[MAX_COMMAND_BUFFER];
+char *command_args[MAX_COMMAND_ARGUMENTS];
+char hashed_color[8];
int embedded=FALSE;
+void print_expand_input(int type){
+ char *seldesc="";
+ if (type==DISPLAY_COMMAND_EXPANSION) return; /* Has its own form, w/ larger */
+ else if (type==DISPLAY_SERVICEDEPENDENCIES){ seldesc=" Dependencies with Host"; }
+ else if (type==DISPLAY_SERVICEESCALATIONS){ seldesc=" Escalations on Host"; }
+ else if (type==DISPLAY_HOSTDEPENDENCIES){ seldesc=" Dependencies on/of Host"; }
+ else if (type==DISPLAY_HOSTESCALATIONS){ seldesc=" Escalations for Host"; }
+ printf("Show Only%s:\n",seldesc);
+ printf("",html_encode(to_expand,FALSE));
int main(void){
int result=OK;
@@ -153,8 +170,8 @@
if(display_type!=DISPLAY_NONE){
- printf("\n",CONFIG_CGI);
printf("\n");
+ printf("\n",CONFIG_CGI);
printf("Object Type:\n");
printf("");
@@ -171,12 +188,16 @@
printf("Contact Groups\n",(display_type==DISPLAY_CONTACTGROUPS)?"SELECTED":"");
printf("Timeperiods\n",(display_type==DISPLAY_TIMEPERIODS)?"SELECTED":"");
printf("Commands\n",(display_type==DISPLAY_COMMANDS)?"SELECTED":"");
+ printf("Command Expansion\n",(display_type==DISPLAY_COMMAND_EXPANSION)?"SELECTED":"");
printf("\n");
printf("\n");
+ print_expand_input(display_type);
printf("\n");
- printf("\n");
printf("\n");
+ printf("\n");
/* display context-sensitive help */
@@ -217,6 +238,10 @@
case DISPLAY_HOSTESCALATIONS:
dis
...[email truncated]...
