This is a multipart message in MIME format.
--=_alternative 005DAAE585256CDD_=
Content-Type: text/plain; charset="US-ASCII"
Sorry, I misunderstood what you were trying to do. There are a number of
ways you could get the functionality you want, your config might just get
a little complicated. Keep in mind that a host check can be anything. In
the scenario you describe I might set up my files in the following manner:
1) Setup your host & service definitions as usual.
2) Create a dummy host with a check command that checks the service you
want your real host to be dependant upon.
3) Create a test on your dummy host that is the same as the host check
command.
4) Create a host dependancy making your real host dependant on the dummy
host.
If you don't want the dummy host to show up in the Web UI, just make the
contact for the dummy host a non existent user.
Daniel Koffler
[email protected]
http://www.remics.net
Tel: 514.497.1411
Fax: 206.600.4642
GPG Key ID: 0xA2C6DC83 Fingerprint: 1FD7 3FDF 8A0D 961F 26A2 3EDA AE8F
A874 A2C6 DC83
Frank Sweetser
28/02/2003 03:28 PM
To
[email protected]
cc
Subject
Re: Nagios
On Fri, Feb 28, 2003 at 03:20:37PM -0500, [email protected] wrote:
> Nagios already has the ability to do this through service dependency
> definitions.
I was under the impression that you could make a service depend upon
another
service, not a host depend upon a service?
Frank Sweetser fs at wpi.edu
WPI Network Engineer
Content-Type: text/html; charset="US-ASCII"
trying to do. There are a number of ways you could get the functionality
you want, your config might just get a little complicated. Keep in mind
that a host check can be anything. In the scenario you describe I might
as usual.
command that checks the service you want your real host to be dependant
upon.
that is the same as the host check command.
real host dependant on the dummy host.
show up in the Web UI, just make the contact for the dummy host a non existent
user.
Daniel Koffler
[email protected]
Tel: 514.497.1411
Fax: 206.600.4642
A874 A2C6 DC83
Frank Sweetser <[email protected]>
28/02/2003 03:28 PM
To
[email protected]
cc
Subject
Re: Nagios
> definitions.
I was under the impression that you could make a service depend upon another
--=_alternative 005DAAE585256CDD_=--
