The problems with embedded Perl and Nagios 2.x seem to be platform
specific since 2.0a1 builds and does a config check on Mac OS X.
(Thank you very much to Yuval Kogman for his making available OS X and
Gentoo for me to poke around on).
However, there appears to be other issues with _compiling_ embedded
Perl support in other systems.
1 Gentoo Linux
[pasta:~] anwsmh % uname -a
Linux pasta 2.6.7-gentoo-r11 #6 Wed Aug 11 17:34:36 IDT 2004 i686 AMD
Athlon(tm) XP 2400+ AuthenticAMD GNU/Linux
1.1 with ePN
./configure --enable-embedded-perl --with-perlcache ...
make all
cd ./base && make
make[1]: Entering directory `/home/anwsmh/build/nagios-cvs/base'
gcc -g -O2 -D_REENTRANT -D_GNU_SOURCE -DTHREADS_HAVE_PIDS
-fno-strict-aliasing -D_LARGEFILE_SOURCE -D_FILE_OFFSET_BITS=64
-I/usr/lib/perl5/5.8.4/i386-linux-thread-multi/CORE -DHAVE_CONFIG_H
-DNSCORE -o nagios nagios.c broker.o nebmods.o checks.o config.o
commands.o events.o flapping.o logging.o notifications.o sehandlers.o
utils.o retention-base.o xretention-base.o comments-base.o
xcomments-base.o objects-base.o xobjects-base.o statusdata-base.o
xstatusdata-base.o perfdata-base.o xperfdata-base.o downtime-base.o
xdowntime-base.o -Wl,-export-dynamic -rdynamic -L/usr/local/lib
/usr/lib/perl5/5.8.4/i386-linux-thread-multi/auto/DynaLoader/DynaLoader.a
-L/usr/lib/perl5/5.8.4/i386-linux-thread-multi/CORE -lperl -lpthread
-lnsl -ldl -lm -lcrypt -lutil -lc -lm -lnsl -lpthread -lltdl
checks.o(.text+0x3f): In function `run_service_check':
/home/anwsmh/build/nagios-cvs/base/checks.c:123: undefined reference to
`PL_thr_key'
utils.o(.text+0x2e59): In function `my_system':
/home/anwsmh/build/nagios-cvs/base/utils.c
`PL_thr_key'
collect2: ld returned 1 exit status
make[1]: *** [nagios] Error 1
make[1]: Leaving directory `/home/anwsmh/build/nagios-cvs/base'
make: *** [all] Error 2
Ok this is almost certainly a Perl issue since symbol PL_thr_key is
defined in the Perl headers (embedvars.h).
Given the machine owners private comments that he had trouble with
vendor Perls but not after rebuilding Perl, this may be an optimisation
issue with this Perl (and prob is since OS X is Ok).
1.2 without ePN
builds fine
2 Darwin OS X
[eris:~/build_TEMP_ONLY/nagios-cvs] anwsmh% uname -a
Darwin eris.woobling.org 8.0.0b1 Darwin Kernel Version 8.0.0b1: Mon Jun
21 20:09:53 PDT 2004; root:xnu/xnu-634.obj~2/RELEASE_PPC Power
Macintosh powerpc
2.1 with ePN
[eris:~/build_TEMP_ONLY/nagios-cvs] anwsmh% make all
cd ./base && make
make[1]: Nothing to be done for `all'.
cd ./cgi && make
gcc -g -O2 -g -pipe -pipe -fno-common -DPERL_DARWIN -no-cpp-precomp
-fno-strict-aliasing -I/usr/local/include
-I/System/Library/Perl/5.8.4/darwin-thread-multi-2level/CORE
-DHAVE_CONFIG_H -DNSCGI -o avail.cgi avail.c getcgi.o cgiutils.o
cgiauth.o objects-cgi.o xobjects-cgi.o statusdata-cgi.o
xstatusdata-cgi.o
ld: multiple definitions of symbol _last_command_check
cgiutils.o definition of _last_command_check in section (__DATA,__data)
xstatusdata-cgi.o definition of _last_command_check in section
(__DATA,__common)
ld: multiple definitions of symbol _last_log_rotation
cgiutils.o definition of _last_log_rotation in section (__DATA,__data)
xstatusdata-cgi.o definition of _last_log_rotation in section
(__DATA,__common)
make[1]: *** [avail.cgi] Error 1
2.2 without
.. gcc -g -O2 -DHAVE_CONFIG_H -DNSCGI -o avail.cgi avail.c getcgi.o
cgiutils.o cgiauth.o objects-cgi.o xobjects-cgi.o statusdata-cgi.o
xstatusdata-cgi.o
all clean.
To sum up, it appears that there will be platform specific issues for
embedding Perl in Nagios 2.0.
However, it seems likely that Nag 2.0 will embed contemporary Perls
(5.6+) since while the CGIs won't compile on OS X, the Nag binary runs
Ok.
Nick Ing-Simmon (perlxs list) says,
'Why not embed a threaded (perl5.6+ style) perl?
Note then even here you either need the mutex locks or every thread
needs to create its own perl instance.'
He should know.
FreeBSD 4.x use
...[email truncated]...
