On 11/27/2012 02:51 PM, Ricardo Jose Maraschini wrote:
> Hya,
> calloc already sets memory to 0 and i think that if we already have
> a function to verify if a given char is an space, we should use it.
> ok? comments?
"isspace()" takes locale into account, but nagiostats will only ever
read 7-bit ascii as syntactically important, so that part of the patch
is wrong. "isspace()" also takes form feeds and vertical tabs, which
the current code doesn't.
The memset() part of the patch is technically correct. The gains of
removing it is about one nanosecond per program start, but since
it's an easy fix I'll apply it anyway.
OP5 AB www.op5.se
on peace.
