Hallo,
our test Nagios dies after every restart with a segmentation fault since la=
st=20
week.
I have tried to find the error with gdb. I hope someone can point me to my=
=20
error.
d139:/etc/nagios/objects/hosts #=20
gdb --args /usr/sbin/nagios /etc/nagios/nagios.cfg=20
GNU gdb 6.6
Copyright (C) 2006 Free Software Foundation, Inc.
GDB is free software, covered by the GNU General Public License, and you are
welcome to change it and/or distribute copies of it under certain condition=
s.
Type "show copying" to see the conditions.
There is absolutely no warranty for GDB. Type "show warranty" for details.
This GDB was configured as "x86_64-suse-linux"...
(no debugging symbols found)
Using host libthread_db library "/lib64/libthread_db.so.1".
(gdb) run
Starting program: /usr/sbin/nagios /etc/nagios/nagios.cfg
[Thread debugging using libthread_db enabled]
[New Thread 47105982427648 (LWP 15658)]
Nagios 3.0rc2
Copyright (c) 1999-2008 Ethan Galstad (http://www.nagios.org)
Last Modified: 01-29-2008
License: GPL
Nagios 3.0rc2 starting... (PID=3D15658)
Local time is Tue Feb 12 10:37:24 CET 2008
[New Thread 1082132800 (LWP 15661)]
Program received signal SIGSEGV, Segmentation fault.
[Switching to Thread 47105982427648 (LWP 15658)]
0x000000000043b90a in process_check_result_queue ()
(gdb) bt
#0 0x000000000043b90a in process_check_result_queue ()
#1 0x000000000041c536 in reap_check_results ()
#2 0x0000000000429119 in handle_timed_event ()
#3 0x0000000000429701 in event_execution_loop ()
#4 0x00000000004120fe in main ()
(gdb) s
Single stepping until exit from function process_check_result_queue,=20
which has no line number information.
0x0000000000437c50 in sighandler ()
(gdb) s
Single stepping until exit from function sighandler,=20
Caught SIGSEGV, shutting down...
0x00002ad7b7394c10 in __restore_rt () from /lib64/libc.so.6
(gdb) s
Single stepping until exit from function __restore_rt,=20
(gdb) s
(gdb)
Regards
=2D-=20
Christian Schneemann
=2D------------------------------------
SUSE LINUX Products GmbH,
Maxfeldstr. 5, D - 90409 N=FCrnberg
Phone:=A0=A0+49 (0)911 - 740 53 0
e-mail:=[email protected]
SUSE LINUX Products GmbH, GF: Markus Rex
HRB 16746 (AG N=FCrnberg)
