Re: [Nagios-devel] Nagios implied and additive inheritance;
On 03/29/2012 07:48 AM, Thomas Guyot-Sionnest wrote:
> On 12-03-28 01:46 PM, Jochen Bern wrote:
>> The fact of the matter is that in
>> xdata/xodtemplate.c:xodtemplate_read_config_data(), you have calls - i=
n
>> this order - to
>=20
>> 1. xodtemplate_resolve_objects(), which [...] applies
>> all templates [and] does the additive inheritance,
>> 2. xodtemplate_clean_additive_strings(), which silently removes any
>> surviving "+" from contacts and contact groups settings of all
>> objects except host and service escalations, and
>> 3. xodtemplate_inherit_object_properties(), which does the host-to-
>> service inheritance.
>=20
> So indeed changing things around isn't going to work, however there
> might be another way to fix it. [...]
> In #2, remove the +'es *except the first one* for anything that will be
> processed by xodtemplate_inherit_object_properties()
Sorry, I misspoke. xodtemplate_clean_additive_string() (which is the
workhorse called from xodtemplate_clean_additive_strings()) removes only
*leading* '+'s in the first place.
You might also want to note that someone, on 03/05/08, moved the calls
to xodtemplate_clean_additive_string() affecting the contacts and
contact groups (=3D: CaCG) of host and service (=3D: HaS) *escalations* o=
ut
of xodtemplate_clean_additive_strings() and into
xodtemplate_inherit_object_properties() (*), so that additive
inheritance of CaCG *does* work from HaS to their escalations. I can
only assume that there was a tangible reason *not* to wholesale move the
cleaning to the end of xodtemplate_inherit_object_properties() and make
additive inheritance the norm for cross-object-type inheritance, like it
already is for template-to-object inheritance.
(*) and added explicit calls to actually *do* the additive inheritance
Regards,
J. Bern
--=20
7
Unternehmenssitz Weiterstadt, Gesch=E4ftsf=FChrer Metin Dogan, Oliver Mic=
hel
