Ethan Galstad wrote:
> Gaspar, Carson wrote:
>>> -----Original Message-----
>>> From: [email protected]
>>> [mailto:[email protected]] On Behalf
>>> Of Ethan Galstad
>>> Sent: Monday, December 11, 2006 3:05 PM
>>> To: Nagios-Devel
>>> Subject: Re: [Nagios-devel] [PATCH] Fix to allow incomplete
>>> service dependency templates
>>> Jason Hoos wrote:
>>>> Since it's not a registered object, the servicedependency template
>>>> should be valid, but Nagios reports "Could not expand dependent
>>>> hostgroups and/or hosts specified in service dependency" instead.
>>> Actually, I think this should result in an error message, even
>>> though the template dependency isn't going to be registered.
>>> Better to catch a problem earlier, rather than later when the
>>> template is being used.
>> I violently disagree. Templates are, by definition, semantically
>> incomplete. Why is this config line any more or less vital than every
>> other missing config line? By your logic, templates shouldn't exist at
>> all.
> You are partially correct. Templates are usually incomplete, but they
> should not contain incorrect data. In your example the template
> references a hostgroup, which in turn has a bad membership list (one
> host does not exist).
> Ethan Galstad,
> Nagios Developer
> Email: [email protected]
> Website: http://www.nagios.org
I apologize for the slightly bad example, in that it led things in the
wrong direction. For sake of argument, say that host "b" does exist.
Even if all prerequisites (hosts a and b, the generic-host template,
etc.) are properly defined, this snippet will *still* give you an error,
even though there shouldn't be anything wrong with the servicedependency
template. The underlying problem is that the code skips validation on
host and service dependencies only if all of hostgroup_name, host_name,
dependent_hostgroup_name, and dependent_host_name are null. The patch
changes the logic so that the validations are skipped if either
hostgroup_name and host_name are null, or dependent_hostgroup_name and
dependent_host_name are null. In other words, if you either haven't
specified any source information, or you haven't specified any dependent
information, then it skips the check; without the patch you have to not
specify all of it before it'll realize it's dealing with a partial template.
Hopefully that explains things better...
Jason
