Re: [Nagios-devel] check_snmp Changed Behavior
On 06/15/2012 01:13 PM, Jochen Bern wrote:
> Quick question: I'm comparing versions 1.4.14 and 1.4.15 of check_snmp
> and found two differences that I suspect not to be intentional. Does
> someone happen to know for sure?
You'll want to direct this question to nagiosplug-devel@ I think.
OP5 AB www.op5.se
on peace.
