This message is in MIME format. The first part should be readable text,
while the remaining parts are likely unreadable without MIME-aware tools.
Send mail to [email protected] for more info.
--1187979219-1610140064-1017419547=:17117
Content-Type: TEXT/PLAIN; charset=US-ASCII
Hi all,
Attached is a patch to the spec file in 1.0a7 so that it works with the
new split .cfg file, as well as the ability to easily add features like
template-based objects/extinfo, embedded perl interpreter, etc.
All the extra features are disabled by default.
HTH,
Ole Gjerde
Content-Type: TEXT/PLAIN; charset=US-ASCII; name="nagios-spec.patch"
Content-Transfer-Encoding: BASE64
Content-ID:
Content-Description:
Content-Disposition: attachment; filename="nagios-spec.patch"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...[email truncated]...
