Issue with command definition
smalldragoon2
Hello
I'm a new user of nagios, I already managed to create multiple devices , services..etc...
Now I have an error that I don't understand
i have create a new command
command_name check_snmpv1
command_line $USER1$/check_snmp -C public -H $HOSTADDRESS$ -o $ARG1$ -w $ARG2$ -c $ARG3$ -l $ARG
5$ -u $ARG4$
this command is in a file ( commands.cfg ) which is read by nagios ( I'm sure of this as all the other commands are in this file ..)
I created some services with this command , but I have the following error while verifying the nagios.cfg
Reading configuration data...
Read main config file okay...
Processing object config file '/usr/local/etc/nagios/hostgroups.cfg'...
Processing object config directory '/usr/local/etc/nagios/objects'...
Processing object config file '/usr/local/etc/nagios/objects/timeperiods.cfg'...
Processing object config directory '/usr/local/etc/nagios/objects/hosts'...
Processing object config file '/usr/local/etc/nagios/objects/hosts/localhost.cfg'...
Processing object config file '/usr/local/etc/nagios/objects/hosts/Cerber.cfg'...
Processing object config file '/usr/local/etc/nagios/objects/hosts/Downloads.cfg'...
Processing object config file '/usr/local/etc/nagios/objects/hosts/HP3052N.cfg'...
Processing object config file '/usr/local/etc/nagios/objects/hosts/Free_fr_GW.cfg'...
Processing object config file '/usr/local/etc/nagios/objects/hosts/esx01.cfg'...
Processing object config file '/usr/local/etc/nagios/objects/hosts/esx02.cfg'...
Processing object config file '/usr/local/etc/nagios/objects/hosts/ESX00.cfg'...
Processing object config file '/usr/local/etc/nagios/objects/hosts/bc-mgmt1.cfg'...
Processing object config directory '/usr/local/etc/nagios/objects/services'...
Processing object config file '/usr/local/etc/nagios/objects/services/localhost.cfg'...
Processing object config file '/usr/local/etc/nagios/objects/services/CERBER.cfg'...
Processing object config file '/usr/local/etc/nagios/objects/services/ESX00.cfg'...
Processing object config file '/usr/local/etc/nagios/objects/services/HP3052N.cfg'...
Processing object config file '/usr/local/etc/nagios/objects/services/Downloads.cfg'...
Processing object config file '/usr/local/etc/nagios/objects/services/Free_fr_GW.cfg'...
Processing object config file '/usr/local/etc/nagios/objects/services/IBM.cfg'...
Processing object config file '/usr/local/etc/nagios/objects/printer.cfg'...
Processing object config file '/usr/local/etc/nagios/objects/contacts.cfg'...
Processing object config directory '/usr/local/etc/nagios/objects/backup'...
Processing object config directory '/usr/local/etc/nagios/objects/backup/services'...
Processing object config directory '/usr/local/etc/nagios/objects/backup/hosts'...
Processing object config file '/usr/local/etc/nagios/objects/templates.cfg'...
Processing object config file '/usr/local/etc/nagios/objects/commands.cfg'...
Checking services...
Error: Service check command 'check_snmpv1' specified in service 'Chassis Cooling - Bay 1' for host 'bc-mgmt1' not defined anywhere!
Error: Service check command 'check_snmpv1' specified in service 'Chassis Cooling - Bay 2' for host 'bc-mgmt1' not defined anywhere!
Error: Service check command 'check_snmpv1' specified in service 'Power Domain 1: Utilization' for host 'bc-mgmt1' not defined anywhere!
Error: Service check command 'check_snmpv1' specified in service 'Power Domain 2: Utilization' for host 'bc-mgmt1' not defined anywhere!
Error: Service check command 'check_snmpv1' specified in service 'Power Module Cooling - Bay 1' for host 'bc-mgmt1' not defined anywhere!
Error: Service check command 'check_snmpv1' specified in service 'Power Module Cooling - Bay 1 Fans' for host 'bc-mgmt1' not defined anywhere!
Error: Service check command 'check_snmpv1' specified in service 'Power Module Cooling - Bay 2' for host 'bc-mgmt1' not defined anywhere!
Error: Service check command 'check_snmpv1' specified in service 'Power Module Cooling - Bay 2 Fans' for host 'bc-mgmt1' not defined anywhere!
Error: Service check command 'check_snmpv1' specified in service 'Power Module Cooling - Bay 3' for host 'bc-mgmt1' not defined anywhere!
Error: Service check command 'check_snmpv1' specified in service 'Power Module Cooling - Bay 3 Fans' for host 'bc-mgmt1' not defined anywhere!
Error: Service check command 'check_snmpv1' specified in service 'Power Module Cooling - Bay 4' for host 'bc-mgmt1' not defined anywhere!
Error: Service check command 'check_snmpv1' specified in service 'Power Module Cooling - Bay 4 Fans' for host 'bc-mgmt1' not defined anywhere!
Error: Service check command 'check_snmpv1' specified in service 'Temperature' for host 'bc-mgmt1' not defined anywhere!
Checked 34 services.
Checking hosts...
Warning: Host 'bc-mgmt1' has no default contacts or contactgroups defined!
Checked 9 hosts.
Checking host groups...
Checked 9 host groups.
Checking service groups...
Checked 0 service groups.
Checking contacts...
Checked 1 contacts.
Checking contact groups...
Checked 1 contact groups.
Checking service escalations...
Checking service dependencies...
Checked 0 service dependencies.
Checking host escalations...
Checked 0 host escalations.
Checking host dependencies...
Checked 0 host dependencies.
Checking commands...
Checked 24 commands.
Checking time periods...
Checked 5 time periods.
Checking for circular paths between hosts...
Checking for circular host and service dependencies...
Checking misc settings...
Total Warnings: 1
Total Errors: 13
any insight ? I guess I'm missing something basic but i don't see what...
Thx
5$ -u $ARG4$
Checking hosts...
Checked 9 hosts.
Checked 1 contacts.
Total Warnings: 1
Total Errors: 13
Thx
Re: Issue with command definition
Is the file that you added the command definition to included in the main nagios.cfg file?
smalldragoon2
yes, look at the last line
it says "Processing object config file '/usr/local/etc/nagios/objects/commands.cfg'..."
this is why I don't understand ...
smalldragoon2
up ? anyone has an idea???
Can I see a sample config of one of those services that's calling the command?
smalldragoon2
Sure !
here it is
command_line $USER1$/check_snmp -H $HOSTADDRESS$ $ARG1$
5$ -u $ARG4$
check_snmp is found and available, not check_snmpv1 !!!
here it is
5$ -u $ARG4$
tonyyarusso
Could you include the *service* definition in addition to the command one?
smalldragoon2
here is the export of all the cfg files loaded in the direcotry services
# Service configuration file
# Created by: Nagios QL Version 3.0.4
# Date: 2011-02-21 12:06:05
# Version: Nagios 3.x config file
# Nagios QL will overwite all manual settings during the next update
host_name Cerber
hostgroup_name freebsd-servers
service_description ALIVE
display_name ALIVE
register 1
host_name Cerber
hostgroup_name DMZ
service_description SSH
check_command check_ssh
register 1
# END OF FILE
host_name Downloads
hostgroup_name windows-servers
display_name ALIVE
max_check_attempts 3
check_interval 3
retry_interval 3
passive_checks_enabled 1
check_period 24x7_sans_holidays
register 1
# END OF FILE
host_name ESX00
hostgroup_name DMZ,ESXs
service_description PING
check_command check_ping!100.0,20%!500.0,60%
register 1
# END OF FILE
host_name Free_fr_GW
hostgroup_name EXTERNAL
register 1
# END OF FILE
host_name HP3052N
service_description Printer alive
register 1
# END OF FILE
host_name bc-mgmt1
service_description Chassis Cooling - Bay 1
check_command check_snmpv1!.1.3.6.1.4.1.2.3.51.2.2.3.20.0!1600:1200,2100:2600!1200:0,2600:3000!RPM!Chassis Cooling - Bay 1
notes View PNP RRD grap
action_url /pnp/index.php?host=$HOSTNAME$&srv=$SERVICEDESC$
register 1
host_name bc-mgmt1
service_description Chassis Cooling - Bay 2
check_command check_snmpv1!.1.3.6.1.4.1.2.3.51.2.2.3.21.0!1600:1200,2100:2600!1200:0,2600:3000!RPM!Chassis Cooling - Bay 2
register 1
host_name bc-mgmt1
service_description Power Domain 1: Utilization
check_command check_snmpv1!.1.3.6.1.4.1.2.3.51.2.2.10.1.1.1.10.1!2600:2400!2880:2600!W!Power Domain 1: Utilization
register 1
host_name bc-mgmt1
service_description Power Domain 2: Utilization
check_command check_snmpv1!.1.3.6.1.4.1.2.3.51.2.2.10.1.1.1.10.2!2600:2400!2880:2600!W!Power Domain 2: Utilization
register 1
host_name bc-mgmt1
service_description Power Module Cooling - Bay 1
check_command check_snmpv1!.1.3.6.1.4.1.2.3.51.2.2.6.1.1.6.1!6200:5400,6700:7000!5300:0,7000:7500!RPM!Power Module Cooling - Bay 1
register 1
host_name bc-mgmt1
service_description Power Module Cooling - Bay 1 Fans
check_command check_snmpv1!.1.3.6.1.4.1.2.3.51.2.2.6.1.1.4.1!2:1!1:0!Fans present!Power Module Cooling - Bay 1
register 1
host_name bc-mgmt1
service_description Power Module Cooling - Bay 2
check_command check_snmpv1!.1.3.6.1.4.1.2.3.51.2.2.6.1.1.6.2!6200:5400,6700:7000!5300:0,7000:7500!RPM!Power Module Cooling - Bay 2
register 1
host_name bc-mgmt1
service_description Power Module Cooling - Bay 2 Fans
check_command check_snmpv1!.1.3.6.1.4.1.2.3.51.2.2.6.1.1.4.2!2:1!1:0!Fans present!Power Module Cooling - Bay 2
register 1
host_name bc-mgmt1
service_description Power Module Cooling - Bay 3
check_command check_snmpv1!.1.3.6.1.4.1.2.3.51.2.2.6.1.1.6.3!6200:5400,6700:7000!5300:0,7000:7500!RPM!Power Module Cooling - Bay 3
register 1
host_name bc-mgmt1
service_description Power Module Cooling - Bay 3 Fans
check_command check_snmpv1!.1.3.6.1.4.1.2.3.51.2.2.6.1.1.4.3!2:1!1:0!Fans present!Power Module Cooling - Bay 3
register 1
host_name bc-mgmt1
service_description Power Module Cooling - Bay 4
check_command check_snmpv1!.1.3.6.1.4.1.2.3.51.2.2.6.1.1.6.2!6200:5400,6700:7000!5300:0,7000:7500!RPM!Power Module Cooling - Bay 4
register 1
host_name bc-mgmt1
service_description Power Module Cooling - Bay 4 Fans
check_command check_snmpv1!.1.3.6.1.4.1.2.3.51.2.2.6.1.1.4.2!2:1!1:0!Fans present!Power Module Cooling - Bay 4
register 1
host_name bc-mgmt1
service_description Temperature
check_command check_snmpv1!.1.3.6.1.4.1.2.3.51.2.2.1.5.1.0!33!38!C!Input temperature
register 1
# END OF FILE
host_name localhost
service_description Current Load
use local-service
check_command check_local_load!5.0,4.0,3.0!10.0,6.0,4.0
register 1
host_name localhost
service_description Current Users
use local-service
check_command check_local_users!20!50
register 1
host_name localhost
service_description HTTP
use local-service
check_command check_http
notifications_enabled 0
register 1
host_name localhost
use local-service
register 1
host_name localhost
service_description Root Partition
use local-service
check_command check_local_disk!20%!10%!/
register 1
host_name localhost
use local-service
register 1
host_name localhost
service_description Swap Usage
use local-service
check_command check_local_swap!20!10
register 1
host_name localhost
service_description Total Processes
use local-service
check_command check_local_procs!250!400!RSZDT
register 1
# END OF FILE
###############################################################################Re: Issue with command definition
Were the command configs written successfully to file with NagiosQL?
Also, if you have spaces in your arguments, try putting them into quotes and see if that makes a difference.
check_snmpv1!.1.3.6.1.4.1.2.3.51.2.2.3.20.0!1600:1200,2100:2600!1200:0,2600:3000!RPM!'Chassis Cooling - Bay 1'
