Re: [Nagios-devel] -epn seems not work in 3.x
Hi List, hi Ethan,
Ethan Galstad schrieb:
> Thanks for the note Peter - I'll post a patch to CVS which should fix
> this.
Patch fixes this behavior.
# nagios: -epn --> disable ePN for particular Plugs
# nagios: +epn --> enable ePN for particular Plugs.
Thanks for this.
Hendrik
