-------- Original-Nachricht --------
> Datum: Thu, 29 Apr 2010 20:46:32 +0200
> Von: Andreas Ericsson
> Betreff: [Nagios-devel] Nagios development moving forward
> Those of you who are git-savvy since before can try
> git log -p --grep="fix.*#$bug_id_without_leading_zeroes" dev
> in a repo cloned from mine and it'll show you the commits that
> are responsible for fixing your problem.
I only get
fatal: ambiguous argument 'dev': unknown revision or path not in the working tree.
Use '--' to separate paths from revisions
when issuing this command.
I have to add "origin/" to the branch, so the command I use is
git log -p --grep="fix.*#$bug_id_without_leading_zeroes" origin/dev
It took me some minutes to figure that out, and maybe someone else
will find this information helpful.
By the way, the command 'git log -p --grep="fix.*#8" origin/dev'
lists all bug ids beginning with 8 (8, 80, 81, 84394 etc.)
so if you're looking for the given bug id only, you can use:
git log -p --grep="fix.*#$bug_id_without_leading_zeroes[^0-9]" origin/dev
At the moment there is not much difference because there's
only one bug id beginning with 8 (80) for example.
Regards
Bernd
GRATIS für alle GMX-Mitglieder: Die maxdome Movie-FLAT!
Jetzt freischalten unter http://portal.gmx.net/de/go/maxdome01
