Re: [Nagios-devel] some feature requests
On 7/6/2006 11:34 AM, Romain Le Merlus wrote:
> -Nagios 3.x will allow for user-specified custom variables in
> -host/service/contact definitions. That means that you'll be
> -able to add
> -your own "criticality" variable and access its value in macros. For
> -example, to define a variable called "criticality", you'll prepend it
> -with an underscore as follows...
> Good morning Ethan,
> Do you already list the differents variables levels for this feature ?
I doubt that, because these variables are *user-specified*. It's up to
you how to use them.
Arno
> Regards.
> Romain Le Merlus
> Fondateur et developpeur du projet Oreon
> http://www.oreon-project.org
> Using Tomcat but need to do more? Need to support web services, security?
> Get stuff done quickly with pre-integrated technology to make your job easier
> Download IBM WebSphere Application Server v.1.0.1 based on Apache Geronimo
> http://sel.as-us.falkag.net/sel?cmd=lnk ... dat=121642
> Nagios-devel mailing list
> [email protected]
IT-Service Lehmann [email protected]
Arno Lehmann http://www.its-lehmann.de
