It sounds the cleanest way, but I don't believe the method currently exists,
you'd have to add it.
Steve
-----Original Message-----
Sent: 18 May 2004 11:54
To: Steve Hanselman
Cc: 'Nagios Developers'
Subject: Re: [Nagios-devel] Deletion of the performance data log files.
Steve Hanselman wrote:
> Might be better to send a request that nagios renames the files, then you
> can process them then delete them?
> Steve
Yes, sounds like a good idea.
My thoughts were converging towards making Nagios fclose() the file
after every write. But this would slow Nagios slightly, and there is
still the very slight risk of a lost line of data. -- But I think your
method is better.
So, using the standard CGI method of passing a command. My code can
submit this, wait for the file to appear, and get on with parsing it.
Nagios would then re-open the original file name and continue to write.
Can you see and problems with this method? Does this method already
exist, or would I have to code it?
Kind regards, Ben
> From: Ben Clewett [mailto:[email protected]]
> Sent: 18 May 2004 11:13
> To: Nagios Developers
> Subject: [Nagios-devel] Deletion of the performance data log files.
> Dear group,
> I have a problem parsing the Nagios performance data and wonder if any
> member can suggest a solution. These have the default file names
> 'serviceperf.log' and 'hostperf.log'.
> I wish to parse and delete these every minute. But I cannot delete them
> as Nagios holds the file open. Stopping and starting Nagios every
> minute is not really an option.
> Really I want to pass a command to Nagios to request the deletion of
> these files. However, if there is a delay between Nagios getting the
> command, and Nagios deleting the files, information will be lost.
> Because my program is sitting waiting for the deletion without parsing.
> Ideally, I would want Nagios to write to a tmp file, then on getting a
> command, close the file, move it to the true file, and open up a new tmp
> file for it's self. Or get Nagios to continuously close the file after
> every write, making it delete-safe. But this might effect performance??
> If any member has any ideas, I would be extremely interested.
> Kind regards, Ben.
> This SF.Net email is sponsored by: SourceForge.net Broadband
> Sign-up now for SourceForge Broadband and get the fastest
> 6.0/768 connection for only $19.95/mo for the first 3 months!
> http://ads.osdn.com/?ad_id=2562&alloc_id=6184&op=click
> Nagios-devel mailing list
> [email protected]
> The information contained in this email is intended for the personal and
confidential use
> of the addressee only. It may also be privileged information. If you are
not the intended
> recipient then you are hereby notified that you have received this
document in error and
> that any review, distribution or copying of this document is strictly
prohibited. If you have
> received this communication in error, please notify Brendata immediately
on:
> +44 (0)1268 466100, or email '[email protected]'
> Brendata (UK) Ltd
> Nevendon Hall, Nevendon Road, Basildon, Essex. SS13 1BX UK
> Registered Office as above. Registered in England No. 2764339
> See our current vacancies at www.brendata.co.uk
> [email protected]
The information contained in this email is intended for the personal and confidential use
of the
...[email truncated]...
Original poster: en Clewett [mailto:[email protected]
