[email protected] wrote:
> Ton Voon schrieb am 13.05.2009 12:27:07:
>>> True that, but obtaining the information right now makes it
>>> prohibitively
>>> expensive to do so for large installations. It would mean having to
>>> walk
>>> through all the hosts and see which ones have the current host
>>> listed as
>>> its parent.
>> True. So if use_large_installations_tweaks is set, don't display,
>> otherwise do?
>> When the children links are added to the object structure, then we
>> just need to remove this if statement.
> I don't like that idea.
> use_large_installation_tweaks=0 is no guarantuee for
> having a small installation present. Personally I do not use it for
> example, since it does have certain caveats. Some people like to
> have full control over their nagios and might make 75% of that
> adjustments that u_l_i_t=1 does, but not the rest because of
> certain problems that arise in their special environment.
> Personally I'd favour some some kind of dynamic model, which
> presents me with a button on the GUI which reads "Press here to
> display all childs of this system" and THEN nagios might go
> crawling the hostslist for children. That'll be a good agreement
> in my opinion.
That would mean adding ajax callbacks, or making a new page just
to display the hosts. I'm not so sure I'd want to go there at the
end of the CGI's lifetime.
OP5 AB www.op5.se
Register now for Nordic Meet on Nagios, June 3-4 in Stockholm
http://nordicmeetonnagios.op5.org/
on peace.
