Good question...
Again this is a case of gcc being just my standard approach to
compiling on Solaris.
I may try firing up a zone and trying with Sun's/Oracle's supplied CC.
Ritchie
Fnord...
On Fri, Nov 12, 2010 at 3:31 PM, Andreas Ericsson wrote:
> On 11/12/2010 04:09 PM, lists wrote:
>> Good point about gmake, I did have a lot of problems with make so
>> wrote my doc for gmake.
>> I tend to do something like:
>> http://s23.org/wiki/Nagios/build/Solaris
>> I have not updated version numbers in that doc so that might not quite w=
ork!
> Do you really need gcc to make it compile? I was under the impression
> that Nagios would work fairly well with any C90-compatible compiler,
> so long as libc on the system has the BSD4.1 stuff we need.
> Andreas Ericsson =C2=A0 =C2=A0 =C2=A0 =C2=A0 =C2=A0 =C2=A0 =C2=A0 =C2=A0 =
=C2=A0 [email protected]
> OP5 AB =C2=A0 =C2=A0 =C2=A0 =C2=A0 =C2=A0 =C2=A0 =C2=A0 =C2=A0 =C2=A0 =C2=
=A0 =C2=A0 =C2=A0 =C2=A0 =C2=A0 www.op5.se
> Tel: +46 8-230225 =C2=A0 =C2=A0 =C2=A0 =C2=A0 =C2=A0 =C2=A0 =C2=A0 =C2=A0=
=C2=A0Fax: +46 8-230231
> Considering the successes of the wars on alcohol, poverty, drugs and
> terror, I think we should give some serious thought to declaring war
> on peace.
