I'm not sure on how to do a backtrace, but if you have some info I'd be
glad to do it.
I had some config options left over from a 1.2 compile that I forgot to
remove, and some double debug stuff from my testing. Cleaned that up
(removed enable-debug0, event-broker, template-extinfo,
template-objects, perlcache, embedded-perl) and still get the same
debug trace. I checked file permissions on the log files and the rw
directory, all owned by nagios and has write permissions to everything.
jl
On Nov 3, 2004, at 5:03 AM, Matthew Kent wrote:
> On Wed, 2004-11-03 at 17:08, Justin Lambert wrote:
>> I have compiled nagios-cvs (latest) on a redhat 9 box and am having
>> troubles with it starting. I first used my configs that I had been
>> using and had problems, so I put in the default nagios.cfg and
>> minimal.cfg and am having the same problem.
>> Configured wtih: ./configure --datadir="/usr/share/nagios"
>> --bindir="/usr/bin" --libexecdir="/usr/lib/nagios/plugins"
>> --localstatedir="/var/log/nagios" --sbindir="/usr/lib/nagios/cgi"
>> --sysconfdir="/etc/nagios" --with-cgiurl="/nagios/cgi-bin"
>> --with-command-user="apache" --with-command-grp="apache"
>> --with-gd-lib="/usr/lib/" --with-gd-inc="/usr/include/"
>> --with-init-dir="/etc/rc.d/init.d/" --with-htmurl="/nagios"
>> --with-lockfile="/var/run/nagios.pid" --with-mail="/bin/mail"
>> --with-nagios-user="nagios" --with-nagios-grp="nagios"
>> --enable-embedded-perl --with-perlcache --with-template-objects
>> --with-template-extinfo --enable-event-broker --enable-DEBUG0
>> --enable-DEBUGALL
> Well first off it might be worth submitting a backtrace to the list to
> look at. If you need instructions on how to go about that I can give
> em.
> Beyond that, initially I had very little luck getting embedded perl to
> work on my RedHat 7.3 install with nagios 2.0, unless you need it, I'd
> remove --enable-embedded-perl and --with-perlcache. I'd also remove
> --enable-event-broker for now unless you are planning on writing one
> (it's not needed for normal operation). Also cosmetically,
> --with-template-objects --with-template-extinfo are no longer required
> and --enable-DEBUGALL supersedes --enable-DEBUG0.
> Best of luck,
> Matthew Kent
> http://magoazul.com
> This SF.Net email is sponsored by:
> Sybase ASE Linux Express Edition - download now for FREE
> LinuxWorld Reader's Choice Award Winner for best database on Linux.
> http://ads.osdn.com/?ad_id=5588&alloc_id=12065&op=click
> Nagios-devel mailing list
> [email protected]
