[Nagios-devel] Custom Object Variables: Contrary to docs,
I'm trying to use special chars in "Custom Object Variables" or "Custom=20
Variable Macros" - the same concept as I under stand it.
That doesn't work. Because they are subjected to "Macro Cleansing"=20
according to "illegal_macro_output_chars" from nagios.cfg.
The doc page "Understanding Macros and How They Work"[1] gives a list of=20
macros to which "Macro Cleansing" is applied, and no custom macros are=20
mentioned. "Cleansing" is also not metioned on the "Custom Object=20
Variables"[2] page.
1: http://nagios.sourceforge.net/docs/3_0/macros.html
2: http://nagios.sourceforge.net/docs/3_0/ ... tvars.html
Applying this patch (against CVS) brings the code and executable=20
behavior in line with the documentation (tested on debian lenny): It'll=20
probably wrap here, so get it at http://pastebin.com/RR4h4eFL instead
cvs diff: Diffing .
Index: macros.c
=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=
RCS file: /cvsroot/nagios/nagios/common/macros.c,v
retrieving revision 1.37
diff -u -r1.37 macros.c
--- macros.c 6 Aug 2010 11:40:46 -0000 1.37
+++ macros.c 27 Aug 2010 12:47:40 -0000
@@ -615,16 +615,10 @@
/***** CUSTOM VARIABLE MACROS *****/
- else if(macro_name[0]=3D=3D'_'){
+ else if(macro_name[0]=3D=3D'_')
/* get the macro value */
result=3Dgrab_custom_macro_value(macro_name,arg[0],arg[1],output);
- /* custom variable values get cleaned */
- if(result=3D=3DOK)
- *clean_options|=3D(STRIP_ILLEGAL_MACRO_CHARS|ESCAPE_MACRO_CHARS);
/* no macro matched... */
else{
#ifdef NSCORE
Any chance of this patch being accepted? If not, the documentation=20
should be updated instead! But I don't see the danger of Custom Object=20
Variables being exempt from escaping. This (bug?) has apparently been=20
there for some time, as it was introduced by:
revision 1.17 date: 2007/10/24 00:54:19;
A rather massive rewrite of the macro logic - phew!
And the first tag after this was: nagios-3-0b6. So I'm guessing it has=20
been there since the birth of the Custom Object Variables.
Peter
--=20
Peter Valdemar M=C3=B8rch
http://www.morch.com
Original poster: ?UTF-8?B?IlBldGVyIFZhbGRlbWFyIE3DuHJjaCAoTGlzdHMpIg==?
