Re: [Nagios-devel] fix request
On Friday August 14 2009 10:27:52 am Roy Sigurd Karlsbakk wrote:
> On 13. aug.. 2009, at 22.00, Holger Wei=DF wrote:
> > * Badri Pillai [2009-08-13 15:00]:
> >> BUT a security bug, which is not only affecting Nagios
> >> but the whole system it is running on,
> >> needs special attention and should be fixed asap
> >> ON all versions of Nagios provides for download (as patch)
> > Support for old release branches is what your Unix or Linux
> > distribution
> > vendor should provide, not necessarily the upstream developers.
> That is bullshit. Why won't you add that fix to the 3.[01].x? Is it
> really that much work?
Sorry. but I can't understand you!
It is not much work, but why should they do it? Just because someone could=
=20
still use this version? It's the normal way to concentrate on the current=20
release and the next release.
> Seems to me the only reason not to do so, is to force people to use
> 3.2.x instead of the old versions.
As Holger said, support for old relaeses you get normally from your=20
distributor.
> I can understand quite well that someone chose to fork out
> Icinga........
Do you think they will do fixes for old releases? Who will you blame if the=
y=20
don't do it?
Greetings,
Christian
> roy
> (+47) 97542685
> [email protected]
> http://blogg.karlsbakk.net/
> I all pedagogikk er det essensielt at pensum presenteres
> intelligibelt. Det er et element=E6rt imperativ for alle pedagoger =E5
> unng=E5 eksessiv anvendelse av idiomer med fremmed opprinnelse. I de
> fleste tilfeller eksisterer adekvate og relevante synonymer p=E5 norsk.
=2D-
>--- Let Crystal Reports handle the reporting - Free Crystal Reports 2008
> 30-Day trial. Simplify your report design, integration and deployment - a=
nd
> focus on what you do best, core application coding. Discover what's new
> with Crystal Reports now. http://p.sf.net/sfu/bobj-july
> Nagios-devel mailing list
> [email protected]
=2D-=20
Christian Schneemann
Operations & Services
=2D------------------------------------
SUSE LINUX Products GmbH,
Maxfeldstr. 5, D - 90409 N=FCrnberg
Phone:=A0=A0+49 (0)911 - 740 53 0
e-mail:=[email protected]
SUSE LINUX Products GmbH, GF: Markus Rex
HRB 16746 (AG N=FCrnberg)
