Re: [Nagios-devel] Tinderbox builds
--001636ed6a827149280471e11870
Content-Type: text/plain; charset=UTF-8
not sure what i'm missing here but I was trying to use the tinderbox_build
on a fresh nagios-head and I get a bunch of error related to the tap
library. Replacing the nagios/tap dir by the original source code branch
from http://people.freebsd.org/~nik/public_d ... .01.tar.gz seem to
magically resolve the issues.
This seem particularly strange to me as the only modification is in the
tap.c file for the threads parts. Anyone has a clue on why I see this and
how to fix it properly? (I was suspecting some autoconf/automake weirdness
related to the generated libtool)
Seb.
On Fri, Aug 21, 2009 at 2:54 PM, Ton Voon wrote:
> On 21 Aug 2009, at 09:52, Hiren Patel wrote:
> Ton Voon wrote:
> Hi!
> I've setup the required central server for Tinderbox builds now. I've
> added a server so this is run every 24 hours now.
> Status page: http://tinderbox.nagios.org/nagios/status.html
> Information page: http://tinderbox.nagios.org (redirects to wiki)
> If you care about Nagios building and running correctly on your
> platform of choice, please take a look at the pages to setup tinderbox
> builds on your systems. I'll be pleased to setup the necessary access
> for you to send your reports to the central server.
> interesting, and nice :)
> what platforms do we currently have builds for?
> That's easy - look at: http://tinderbox.nagios.org/nagios/status.html
> I could add more, but actually, I want more participation from the
> community.
> and which are the most
> common ones we want to start out with?
> Add which ever ones you are interested in. There's the ability to add in
> configure options, so I can see that you may want to test that certain
> configure options work as expected.
> Ton
> Let Crystal Reports handle the reporting - Free Crystal Reports 2008 30-Day
> trial. Simplify your report design, integration and deployment - and focus
> on
> what you do best, core application coding. Discover what's new with
> Crystal Reports now. http://p.sf.net/sfu/bobj-july
> Nagios-devel mailing list
> [email protected]
Content-Type: text/html; charset=UTF-8
Hi,not sure what i'm missing here but I was trying to use the tinde=
rbox_build on a fresh nagios-head and I get a bunch of error related to the=
tap library. Replacing the nagios/tap dir by the original source code bran=
ch from http://people.freebsd.org/~nik/public_d ... .01.tar.gz seem to magically resolve the issues.
This seem particularly strange to me as the only modification is in the tap=
.c file for the threads parts. Anyone has a clue on why I see this and how =
to fix it properly? (I was suspecting some autoconf/automake weirdness rela=
Seb.On Fri, Aug 21, 2009 at 2:54 PM,=
Ton Voon <ton.=
[email protected]> wrote:
On 21=
Aug 2009, at 09:52, Hiren Patel wrote:=
Ton Voon wrote:Hi!
I've setup the required cent=
ral server for Tinderbox builds now. I've =C2=A0added a server so this is run every 24 hours now.
<blockquote type
...[email truncated]...
