Re: [Nagios-devel] Empty host/service-group patch
On 9 Nov 2010, at 14:51, Sven-G=F6ran Bergh wrote:
>> Fr=E5n: Ton Voon
>> Till: Nagios Developers List
>> Skickat: tis 9 november 2010 10:41:14
>> =C4mne: Re: [Nagios-devel] Empty host/service-group patch
>> Nasty! Can you update the test configurations to trigger this bug? =20=
>> Then with
>> your patch we should see that the problem is fixed.
> Here is the patch and a test-case for it. However, I do
> not know if the test is able to catch this bug on all
> setups. I have verified it on i586 and x86-64.
The test case doesn't trigger for me, though I understand it depends =20
on what strtok was doing before. As the test case is still a =20
reasonable test, I've applied your patch (it didn't apply cleanly =20
unfortunately because of some other code re-arranging) and committed =20
into HEAD now.
Thanks.
Ton
