Yes, its enabled.
Here is the configuration of a service:
use generic-service ; Name of service template to use
host_name Central
service_description TEST-IGNORE2
is_volatile 0
check_period 24x7
max_check_attempts 3
normal_check_interval 5
retry_check_interval 1
contact_groups sadmins
notification_interval 0
notification_period 24x7
notification_options c,r
first_notification_delay 10
check_command check_snmp_interface!snmp_here!Loopback66
"NOTIFICATIONTYPE" Macro , as i can see from changelog, still get the
same values. Or is any change to these macros??
Thursday, September 6, 2007, 12:41:08 PM, you wrote:
> Hi there,
> it works fine with Problem alerts and recovery alerts even if the
> service has a first_notification_delay.
> Did you have enabled the "r" option for the contact?
> Regards
> Hendrik
> Brandino Andreas schrieb:
>> Hi all ,
>> I was using nagios 2.9. After the upgrade to 3.0b3 i receive only
>> Notifications with Type==PROBLEM. I dont receive any notifications
>> with type==RECOVERY.
>> The only change i did to the config after the upgrade was to use
>> "first_notification_delay"
>> Any idea what is going on/troubleshoot this ?
>> Regards
>> Brandino Andreas
>> [email protected]
>> This SF.net email is sponsored by: Splunk Inc.
>> Still grepping through log files to find problems? Stop.
>> Now Search log events and configuration files using AJAX and a browser.
>> Download your FREE copy of Splunk now >> http://get.splunk.com/
>> _______________________________________________
>> Nagios-devel mailing list
>> [email protected]
>> https://lists.sourceforge.net/lists/lis ... gios-devel
Brandino Andreas
[email protected]
