------_=_NextPart_001_01C95F98.2B416559
Content-Type: multipart/alternative;
boundary="----_=_NextPart_002_01C95F98.2B416559"
------_=_NextPart_002_01C95F98.2B416559
Content-Type: text/plain;
charset="iso-8859-1"
Hello List,
I believe, I found a bug in ndo2db.c in ndoutils.
Problem is:=20
ndo2db forks a child for each accepted connection.
The Parent process calls waitpid _once_ for each received SIGCHLD.
But *nix does not guarantee the delievery of every SIGCHLD if multiple =
Signals of the same type occur.
--> increasing number of zombies.
Usually this no problem because the number of forks and waits is quite =
small and the probability of lost SIGCHLDs is even smaller (practically =
zero).
In our setup clients close the connection frequently and we have over =
500 Nagios instances reporting to one central ndo2db, which raises the =
number of forks, waits and losses of SIGCHLDs to a significant level.
This patch repeats the call to waitpid until no finished children =
(zombies) are left.
Regards,
Joey5337 / Tilo Renz
Content-Type: text/html;
Bug in ndoutils / ndo2db
Hello List,
Problem is:
zero).
number of forks, waits and losses of SIGCHLDs to a significant =
level.
(zombies) are left.
Regards,
------_=_NextPart_002_01C95F98.2B416559--
Content-Type: text/x-patch;
name="Lost_SIGCHLD.diff"
Content-Description: Lost_SIGCHLD.diff
filename="Lost_SIGCHLD.diff"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------_=_NextPart_001_01C95F98.2B416559--
