Hi Thomas et all,
>Is there anything in it that didn't fit your needs?
I have three issues with OCP_Daemon,
1) It is a hack, albeit a good one. A plugin or built in function would be
better.
2) Configuration management is a PIA. DNX attempts to address this, but
fails in my point 3.
3) It is still very chatty. Ultimately, nagios is a polling(pull) monitor.
>> The nagios server would be configured to monitor the host and services
>> passively and nsca would be installed an running.
>> The nagios agent would monitor the services local and "ping" the server
>> for host alive.
> (M$ Operation Manager), which is, from my experience, a piece of sh*t
I see how that would be a not very useful.
The server would manage and monitor host up/down. There is know way
around that. What I stated above might have been missing leading.
> I will explain a bit more in detail later (stay posted on
> nagiosplug-devel/users lists)
I will join the plugin list.
My vision:
This specially relates to local_services such as process, application,
disk, load, and swap services. Why have the server/network expense to
check if a file system is full on 2000 servers when the each agent can do
it and the notify the server.
Nagios Server
Manages Domain+ configuration*
Monitors host up/down via passive or active host_check_command.
Manages service up/down/flap of nagios.
Nagios agents
Monitors service state
Pushes up/down status change to server via nsca or other built in method.
Subdomain+ configuration proxy*
Subdomain+ nsca proxy(or in nscad)*
Caveates, perf collection is different and I have omitted lots of details.
* Long term wish
+ Nagios (sub)domain: A collections of systems usually geographic. not
dns,nis, etc.
As I stated earlier I am willing to work on this once you guys get to know
me. I used to write software to monitor and manage systems and software
for trading and banking systems. 20,000 plus nodes.
I think all the pieces are there:
Nagios can already monitor and schedule local services checks.
The NSCA protocol and code already exits.
Steve
