Re: [Nagios-devel] Nagios - Attribute based authorization
Dear List,
is there any news, comments in this topic?
Cheers,
Tibor
2010-10-18 11:05 keltez=C3=A9ssel, V=C3=A1g=C3=B3 Tibor =C3=ADrta:
> Dear List,
> the development of this feature has been finished and it had been
> tested in 99% of possible cases. The patch is attached to this e-mail.
> As you can see we work with nagios version 3.2.1.
> Kind Regards,
> Tibor Vago
> 2010-05-21 17:06, Vago Tibor wrote:
>> Dear Andreas,
>> Thansk for the quick answer.
>> We will start the development for this feature and send patch(es) to
>> the ND list.
>> Kind regards,
>> Tibor
>> 2010-05-19 12:15 keltez=C3=A9ssel, Andreas Ericsson =C3=ADrta:
>>> On 05/19/2010 11:03 AM, V=C3=A1g=C3=B3 Tibor wrote:
>>>> Dear Nagios devel-list,
>>>> We would like to use attribute based authority checking in Nagios.
>>>> We use authentication but not SSL-based.
>>>> Our conception is (based nagios-version-3.2.1) the following:
>>>> *Step1*
>>>> cgi/status.c:
>>>> //line136:
>>>> authdata current_authdata;
>>>> //line244:
>>>> get_authentication_information(&current_authdata);
>>>> Add some char variables to authdata structure.
>>>> include/cgiauth.h
>>>> typedef struct authdata_struct{
>>>> char *username;
>>>> int authorized_for_all_hosts;
>>>> int authorized_for_all_host_commands;
>>>> int authorized_for_all_services;
>>>> int authorized_for_all_service_commands;
>>>> int authorized_for_system_information;
>>>> int authorized_for_system_commands;
>>>> int authorized_for_configuration_information;
>>>> int authorized_for_read_only;
>>>> int authenticated;
>>>> //TODO
>>>> char **host_allow_to_see;
>>>> char **service_allow_to_see;
>>>> }authdata;
>>>> *Step2*
>>>> cgi/cgiauth.c
>>>> line86 /* read in authorization override vars from config file... */
>>>> line87 if((thefile=3Dmmap_fopen(get_cgi_config_location()))!=3DNULL)=
>>>> line95 if((input=3Dmmap_fgets_multiline(thefile))=3D=3DNULL)
>>>> line96 break;
>>>> authinfo->username=3D""
>>>> authinfo->authenticated=3DFALSE
>>>> authinfo->authorized_for_all_hosts=3DFALSE;
>>>> authinfo->authorized_for_all_host_commands=3DFALSE;
>>>> authinfo->authorized_for_all_services=3DFALSE;
>>>> authinfo->authorized_for_all_service_commands=3DFALSE;
>>>> authinfo->authorized_for_system_information=3DFALSE;
>>>> authinfo->authorized_for_system_commands=3DFALSE;
>>>> authinfo->authorized_for_configuration_information=3DFALSE;
>>>> authinfo->authorized_for_read_only=3DFALSE;
>>>> // TODO:
>>>> // newlocal variable:
>>>> attribute_server_variable=3D"entitlement";
>>>> *Step3*
>>>> Check the CGI config file is it contains "attribute_server_variable"=
>>>> If it not doesn't contain then we can return just like now.
>>>> If it contains then read its value otherwise the default value is
>>>> "entitlement".
>>>> Then split value about ";" and put that pieces into an array.
>>>> Now we can compare the attribute pieces of array from server variabl=
e
>>>> and attributes from CGI configs.
>>>> Theese compares will be placed in the following functions:
>>>> int is_authorized_for_host(){...}
>>>> int is_authorized_for_service(){...}
>>>> etc.
>>>> Can anyone inform me if this feature is currently under
>>>> development or
>>>> already usable.
>>> It's not under development and it's definitely not already usable.
>>>> If not, we would like to add this feature to the
>>>> Nagios source code cooperate with the developer team. How can I send
>>>> patches or modification?
>>> You can send patches in unified diff format to this list, where I, To=
n
>>> or Ethan will pick them up and put them "somewhere" and evaluate them
>>> for a future release. Note that details about the patch may well be
>>> altered during the review process. If the patch is crap, we'll tell
>>> you
>>> so and give you details about what needs to be
...[email truncated]...
