I'll be removing the hardcoded layout type in the link. That way the
statusmap method used will be whatever the user has configured in the
CGI config file.
Not sure if this patch will stay in or not. This feature used to be
in the code in the NetSaint days (I don't recall which version), but
people complained about too many items on the screen in the overview
window.
On 25 Sep 2003 at 0:07, Creator wrote:
> Hi Chosson,
> you are right. I forgot to include the extinfo.c patch
> Here it is along with the old patch and the updated instructions.
> Here is the patch to locate any host in the status map by single
> clicking the detailed host page.
> Look at the attached screenshots to see a little demo:
> shot1: The red circle shows the new command (Host information page)
> shot2: After clicking the icon you'll be forwarded on the statusmap
> using "Depth Layers" method. shot3: Another point (Status Overview for
> example) from where you can use this function.
> Before applying to Nagios v1.1 code you may want to change a variable
> to reflect your preferred Status Map default display mode.
> Here it is the list as defined in cgi/statusmap.c:
> #define LAYOUT_USER_SUPPLIED 0
> #define LAYOUT_SUBLAYERS 1
> #define LAYOUT_COLLAPSED_TREE 2
> #define LAYOUT_BALANCED_TREE 3
> #define LAYOUT_CIRCULAR 4
> #define LAYOUT_CIRCULAR_MARKUP 5
> #define LAYOUT_CIRCULAR_BALLOON 6
> Look at the diff files and substitute the "layout=3D1" string with
> "layout=3D?" where ? is a number from 0 to 6 to be chosen from the above
> list or just skip this step if you are comfortable with the default
> setting.
> Apply the patch by typing:
> cd /cgi
> patch status.c /locate-on-map.diff
> patch extinfo.c /locate-on-map-extinfo.diff
> make;strip status.cgi extinfo.cgi;cp status.cgi extinfo.cgi nagios installed dir>/sbin
> Now set /sbin/status.cgi and extinfo.cgi
> permissions as those of the other files in that dir and you have
> finished.
> Enjoy!
> > -----Messaggio originale-----
> > Da: CHOSSON [mailto:[email protected]]
> > Inviato: mercoled=EC 24 settembre 2003 21.22
> > A: Creator
> > Oggetto: Re: [Nagios-users] Patch to locate hosts on status
> > map in a fastway
> > Hello,
> > i successfully patch status.c
> > But, where is the patch to obtain the result show in
> > shot1.jpg, because i'm very interested about it.
> > PS: sorry for my poor english.
> > bye,
> > Le jeu 18/09/2003 =E0 00:05, Creator a =E9crit :
> > > Hi there,
> > > here is the patch as promised to locate any host in the
> > status map by
> > > single clicking the detailed host page.
> > > page) shot2: After clicking the icon you'll be forwarded on the
> > > statusmap using "Depth Layers" method. shot3: Another point
> > > (Status Overview for example) from
> > where you can
> > > use this function.
> > a variable
> > > Look at the diff file and substitute the "layout=3D1" string with
> > from the above
> > > default setting.
...[email truncated]...
