--------------050805040206030503070006
Ethan,
One more patch for nrpe (CVS 1-FEB-08) that allows the user to specify
the "nasty metachar" set in the nrpe.cfg file with the new
"nasty_metachar" config option. The default set of nasty metachars is
the same as it always was, if the user chooses not to use the new config
parameter.
I just realized that I probably should have updated the sample-config
files as well, but I forgot. Sorry.
I just sent two other patches for nrpe (also against CVS 1-FEB-08). As
far as I can tell, they should apply in any order, although I've only
tried them in alphabetical order.
John
name="nrpe-cfgmeta-cvs01022008.patch"
Content-Disposition: inline;
filename="nrpe-cfgmeta-cvs01022008.patch"
diff -Naur nrpe/src/nrpe.c nrpe-patched/src/nrpe.c
--- nrpe/src/nrpe.c 2008-01-24 05:45:16.000000000 -0700
+++ nrpe-patched/src/nrpe.c 2008-02-01 16:19:33.000000000 -0700
@@ -42,7 +42,7 @@
#define DEFAULT_COMMAND_TIMEOUT 60 /* default timeout for execution of plugins */
#define MAXFD 64
-#define NASTY_METACHARS "|`&>sizeof(Nasty_Metachars)){
+ syslog(LOG_ERR,"Nasty Metcharacter list too long in config file '%s' - Line %d\n",filename,line);
+ return ERROR;
+ strncpy(Nasty_Metachars,varvalue,sizeof(Nasty_Metachars)-1);
+ Nasty_Metachars[sizeof(Nasty_Metachars)-1]='\0';
+ else{
syslog(LOG_WARNING,"Unknown option specified in config file '%s' - Line %d\n",filename,line);
continue;
@@ -1815,10 +1825,10 @@
int contains_nasty_metachars(char *str){
int result;
- if(str==NULL)
+ if(str==NULL || !Nasty_Metachars[0])
return FALSE;
- result=strcspn(str,NASTY_METACHARS);
+ result=strcspn(str,Nasty_Metachars);
if(result!=strlen(str))
return TRUE;
--------------050805040206030503070006--
