Wolfgang Barth wrote:
> The output of check_multi does not work correctly, if the output is
> formatted with -r2 (HTML formatted). Plain output without HTML Tags is
> correct (and HTML format is not really neccessary
> @Matthias: please, could you check your plugin with ePN enabled, HTML
> formatting and the new p1.pl?
Oops - ePN capability is a point on my TODO list, for the time being its
explicitely switched off by adding '# nagios: -epn'.
Being a bit overcrowded by my relatives at the moment it will take some days
Cheers,
Matthias
http://my-plugin.de/check_multi
