Re: [Nagios-devel] clean_macro_chars() no longer called in utils.c in 2.0b1 ?
Stanley -
You are correct. The macro code was changed shortly before the beta
1 release, and this one fell through the cracks. I am posting a
patch to CVS shortly.
On 4 Feb 2005 at 8:47, Stanley Hopcroft wrote:
> Dear Folks,
> Nagios 2.0b1 appears not to clean illegal characters from certain
> macros as documented.
> Whereas 1.2 has a logical case formed by an 'if then else if ..' chain
> to clean the macro content depending on the macro name, the 2.0b1 code
> relies on a flag named clean_macro that is only cleared (as far as I
> can see).
> tsitc> grep clean_macro utils.c
> int clean_macro=FALSE;
> clean_macro=FALSE;
> if(clean_macro==TRUE)
> strncat(output_buffer,(selected_macro==NULL)?"":clean_macro_chars(sele
> cted_macro,options),buffer_length-strlen(output_buffer)-1); char
> *clean_macro_chars(char *macro,int options){
> /* added cruft */
> printf("\tEntering utils.c/clean_macro_chars.\n");
> printf("\tLeaving utils.c/clean_macro_chars.\n"
> (The last two (2) printfs are added by me to examine why
> clean_macro_chars() wasn't cleaning. It wasn't cleaning because it
> wasn't called).
> This may have been fixed in the CVS and I apologise if it has.
> Would a patch that implements a case selection of the documented
> cleansed macros be acceptable ?
> Yours sincerely.
> Stanley Hopcroft
> IP Australia
> Ph: (02) 6283 3189 Fax: (02) 6281 1353
> PO Box 200 Woden ACT 2606
> http://www.ipaustralia.gov.au
Ethan Galstad,
Nagios Developer
Email: [email protected]
