Re: [Nagios-devel] Event handlers functionality reapplied to Nagios
On 26 Feb 2013, at 11:06, Andreas Ericsson wrote:
> On 02/25/2013 04:31 PM, Ton Voon wrote:
>> Andreas,
>>=20
>> We've noticed that the event handlers do not currently work in Nagios
>> 4 trunk. It seems that there is a FIXME message where the worker part
>> was not implemented.
>>=20
>> We've now implemented this, so I think this is now working as
>> expected.
>>=20
>=20
> The patch is incomplete. There will be no warnings if the eventhandler
> times out, which is what the FIXME comments refer to.
I think this is already implemented. In base/workers.c, there are error =
messages like: "Warning: Service event handler command '%s' timed out =
after %.2f seconds", which is how we knew there were errors initially.
Also, the wproc_run_service_job() calls in =
base/sehandlers.c:obsessive_compulsive_service_check_processor doesn't =
include any timeout code at that function level, so the pattern seems to =
be to implement warnings in base/workers.c.
However, I can see removal of the early_timeout would be valid as this =
is dead code. I will do that if that is the only thing stopping the =
patch from being accepted.
Ton
