Re: [Nagios-devel] fast-scan at startup
Nagios will use the last known next check of a host/service (rather
than rescheduling it) at startup if you set the following option in
your main config file:
Is that what you were looking for?
On 1 Apr 2005 at 7:30, Jason Martin wrote:
> One nice feature that would be handy would be to optionally be
> able to have Nagios do what amounts to a forced check of all
> active services that are within their check period at startup.
> That way restarts can't interrupt the schedule, ie a check that
> is scheduled to occur once every 60 minutes won't get
> rescheduled out 60 minutes, making for a 120 minute interval.
> The scenario is that a 60-minute interval check is 1 minute away
> from firing when Nagios is restarted. Nagios then reschedules
> the check out 60 minutes. Optionally doing a global
> forced-check at startup means that this scenario won't happen.
> Thanks,
> -Jason Martin
> A day without radiation is a day without sunshine.
> This message is PGP/MIME signed.
Ethan Galstad,
Nagios Developer
Email: [email protected]
