Monitor AIX LPAR using Nagios XI VM Image
xyrus1
Post by xyrus1 »
I am trying to monitor AIX LPAR using Nagios XI VM Image. I think, i can use SNMP Trap Wizard to monitor it.
Have gone through the documentation at
http://assets.nagios.com/downloads/nagi ... ith_XI.pdf
and installed the NagiosXI-SNMPTrap.sh on CentOS.
However, after configuration, the status shows "Pending" and status information shows "No check results for service yet..."
Not sure, if I should use SNMP Wizard instead ?
Thanks.
tonyyarusso
Re: Monitor AIX LPAR using Nagios XI VM Image
Post by tonyyarusso »
Have you configured the AIX box to send SNMP traps to the Nagios machine yet? Have you installed and configured any necessary MIBs?
Tony Yarusso
Technical Services
___
TIES
Web: http://ties.k12.mn.us/
