Re: [Nagios-devel] Nagios acknowledgement enhancement request
Hash: SHA1
On 12/11/08 04:45 PM, Jim Winkle wrote:
> Hi,
> I have a suggestion for a future enhancement of Nagios.
> In short, I'd like there to be a way to have Nagios send notifications
> until we acknowledge a problem -- for certain unique plugins -- without
> ignoring future problems. Background and more details follow.
> We're using the check_logfiles plugin to monitor syslogs (e.g.
> /var/adm/messages on Solaris). check_logfiles returns CRITICAL when it
> detects a problem, but then normally clears itself (returns OK) the next
> time it runs. Nagios notifies us only once under this scenerio, and since
> it's possible that pagers might miss just one page (paging services aren't
> 100% reliable), we'd rather get notified until we explicitly acknowledge
> the problem.
> The check_logfiles plugin does have the capability to continue to report the
> error (using its "sticky" option). This is good since then we're notified
> longer, but if we then use the Nagios "Acknowledge" link to acknowledge the
> problem, new problems (e.g. new errors in /var/adm/messages) reported by the
> check_logfiles plugin get ignored.
> I asked on the nagios-users list if there was a way to acknowledge a problem
> reported by a plugin like check_logfiles without ignoring future problems.
> Nobody came up with a way, so I assume this is new functionality needed in
> Nagios.
> I realize we can syslog an "okpattern" string and check_logfiles will then
> clear, but I'm looking for something using the Nagios web (and external
> command_file) interfaces. Using the Nagios "Acknowledge" link would be ideal,
> since that's what folks are going to be using to acknowledge other problems.
> I'm using Nagios version 3.0.5 and check_logfiles version 2.4.1.3. We configure
> check_logfiles as a volatile service and use state staulking.
> Thanks for providing these great tools! Please let me know if something doesn't
> make sense or if I'm missing something.
You could most likely achieve what you want with adaptive monitoring.
When the service goes to HARD CRITICAL, run an event handler that change
the service command to a dummy critical check. To change it back you
could either submit a passive check that triggers the event handler to
re-apply the check command, or use a dummy contact whose notification
command do it upon receiving an acknowledgement.
Some useful links:
http://nagios.sourceforge.net/docs/3_0/ ... dlers.html
http://nagios.sourceforge.net/docs/3_0/adaptive.html
http://www.nagios.org/developerinfo/ext ... ndlist.php
Thomas
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.4.6 (GNU/Linux)
Comment: Using GnuPG with Mozilla - http://enigmail.mozdev.org
iD8DBQFJG2Uv6dZ+Kt5BchYRAnyuAJ9tIWxE+AvhioJK5To1WLf/tcMzfgCg8YKZ
YyMtLnDmpua+VY/Puy4qMEg=
=ikaK
-----END PGP SIGNATURE-----
