Re: [Nagios-devel] [BUG] Missing new line in cmd.cgi [3.0.5]
Olivier Beytrison wrote:
> Hi there,
> I juste upgraded nagios to 3.0.5 and discovered a little bug with the
> command cgi.
> If you want to submit a command (like Disable notifications for all
> services on this host) and you check "Disable notification for host
> too", the command is not correctly sent to Nagios.
> Here's the logfile result (:
> [1225963577] EXTERNAL COMMAND:
> ENABLE_HOST_SVC_NOTIFICATIONS;hesidp[1225963577]
> ENABLE_HOST_NOTIFICATIONS;hesidp
> As you can see, there's a missing new line, thus making 2 commands on
> one line, and unreadable for nagios.
> I saw that the code of cgi/cmd.c has been changed, I tried to simply add
> a \n in the cmd_submitf() function, but didn't work.
> could you please look into this problem, and submit a patch ?
I'll look into it, yes. Thanks for reporting it.
OP5 AB www.op5.se
