[Nagios-devel] Large installation CGI optimization patch
--_000_D26A6FD0353F784CB75381CF3D2043E19B5C879DMBX02ldschurcho_
Content-Type: text/plain; charset="ISO-8859-1"
I have been working on a simple change to the xsddefault.c file which seems=
to be a good optimization for large installations. Our installation has 43=
,500 services and 4,200 hosts. The CGI's tend to take a while to go through=
the status.dat file as a result. The way that the routine is written to re=
ad in the status.dat file has some design drawbacks that make it interpret =
the lines more slowly than it could.
If the status.dat file is uncorrupted (which if it is corrupted, there are =
more problems than reading that file in), then the order of testing for dif=
ferent types of data on the line consumes more time than it should. If you =
are already inside a definition of a service, host, or whatever, there is n=
o reason to test whether you are going to run into another object definitio=
n start line until after you have ended the definition that you are current=
ly in. The optimization that I have made just takes that into account, and =
it no longer has to do 10 strcmp() calls for every line it reads. When an o=
bject definition starts (e.g. "hoststatus {"), just set a flag, then clear =
it when you get to the end ("}"). Then when you look at a line, don't look =
for the possible definition lines, just check the flag and look for variabl=
e/value pair (var=3Dvalue).
In our case, the speed increase is not dramatic, but it is significant. The=
average time to execute for one of the CGI's was reduced by .7 seconds. Wh=
ile this is only about 10%, this reduces the load on the web server signifi=
cantly when there are many requests for these pages. In some cases (when th=
e server is busy) it reduces the execution time by as much as 3 seconds, wh=
ich is more like 40%.
I'm submitting this modification for evaluation and comment. Hopefully it c=
an make it into the Nagios code base.
Cary Petterborg
Below is the output of a diff of xsddefault.c from the version of 3.2.1 tha=
t we are currently using (*most* of the differences are just the indentatio=
n of the section that is now enclosed within an if statement):
Index: xsddefault.c
=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=
--- xsddefault.c (revision 1955)
+++ xsddefault.c (working copy)
@@ -766,6 +766,7 @@
unsigned long triggered_by=3D0;
unsigned long duration=3D0L;
int x=3D0;
+ int in_block =3D FALSE;
/* initialize some vars */
@@ -815,47 +816,66 @@
if(input[0]=3D=3D'#' || input[0]=3D=3D'\x0')
continue;
- else if(!strcmp(input,"info {"))
- data_type=3DXSDDEFAULT_INFO_=
DATA;
- else if(!strcmp(input,"programstatus {"))
- data_type=3DXSDDEFAULT_PROGR=
AMSTATUS_DATA;
- else if(!strcmp(input,"hoststatus {")){
- data_type=3DXSDDEFAULT_HOSTS=
TATUS_DATA;
- temp_hoststatus=3D(hoststatu=
s *)malloc(sizeof(hoststatus));
- if(temp_hoststatus){
- temp_hoststa=
tus->host_name=3DNULL;
- temp_hoststa=
tus->plugin_output=3DNULL;
- temp_hoststa=
tus->long_plugin_output=3DNULL;
- temp_hoststa=
tus->perf_data=3DNULL;
- temp_hoststa=
tus->check_options=3D0;
- else if(!strcmp(input,"services
...[email truncated]...
