[Nagios-devel] Re: [netsaint] Grrr. Embedded Perl argument processing breaks Perl service handlers.
Dear Ladies and Gentlemen,
This problem is unfortunately deeply rooted in Netsaints design goal of
having /bin/sh run the service checks.
/bin/sh wants to be passed a string like
Program 'This is the first arg' 'the second arg' and the rest
which it will then parse iteslf in the expected way.
The embedded Perl interpreter on the other hand wants the arguments
parsed for it and passed to it either as an argument vector or on the
Perl stack - in any case, the arguments are separated by the caller and
not by Perl.
The existing implementation trades off the common case of single word
arguments (against greater complexity) by passing to Perl _one_
argument string containing the command line options and arguments and
having p1.pl split it on white space.
However, Netsaint is already doing extensive argument and command line
processing so it may be possible to exploit this for Perl.
There may therefore be two ways of improving this situation
1 Improve the parsing of the arguments by p1.pl
==> so $ar in pl.pl is processed into @ARGV according to the usual
conventions.
This requires that _all_ potential white space filled arguments are
quoted.
This means that (at least) process_macros() would have to quote the
values of the macros it finds so that p1.pl will eventually see them
quoted and know where the values start and finish.
This seems a bit yukky since _all_ service checks get the quoted values
- conditional on the embedded Perl support.
2 Pass arguments to Perl on the Perl stack.
This could be done by creating a new global array variable and having
process_macros() append each value it finds to that array.
get_raw_command_line() would also have to split the found command line
on white space and add the options/switches to this array also.
eg
for a command command[check_by_ssh]=$USER1$/check_by_ssh -t 30 -H $ARG1$
-l $ARG2$ -C '$ARG3$ $ARG4$
1 split on white space and put the command name in the array
2 for the rest of the command
push it onto the global perl argument array.
This suggests that get_raw_command_line returns the new
global array perl_args[] with
$USER1$,
check_by_ssh,
'', /* reserved for temp file name */
'', /* reserved for cache switch */
-t,
30,
-H,
$ARG1$,
-l ...
and that process_macros processes this array as well as
the raw_command string.
Note that this is _extra_ processing required if embedded Perl support
is defined.
The call to perl_call_argv would then (basically) use this array as its
argument vector and the call to perl_call_pv would push each value from
this list onto the Perl stack. These are trivial changes.
This way requires little change to p1.pl (replacing $ar in p1.pl by the
rest of @_) but substantial hacking elsewhere.
Apart fromm ascertaining that should Perl be called with the arguments
preparsed into array slots, the white space problem goes way, I have
done nothing.
Please would you consider commenting on the 2 approaches suggested above
- I think 2 is the best - or suggest a better way ?
Yours sincerely.
Stanley Hopcroft
'...No man is an island, entire of itself; every man is a piece of the
continent, a part of the main. If a clod be washed away by the sea,
Europe is the less, as well as if a promontory were, as well as if a
manor of thy friend's or of thine own were. Any man's death diminishes
me, because I am involved in mankind; and therefore never send to know
for whom the bell tolls; it tolls for thee...'
from Meditation 17, J Donne.
