[Nagios-devel] PATCH: configure is broken ....
This is a multi-part MIME message
--Boundary-00=_hQC0D9kP4O90OC0
Content-Type: text/plain;
charset="iso-8859-1"
Content-Disposition: inline
while building a new rpm of the actual CVS-Version, i've detected, that some
USE definitions in cgiutils.h where actually not set by configure.
I've traced down the problem to a new version of autoconf being used to
create the configure script.
The problem was, that there are no comments allowed after the #undef
definition, which was obviously not honored by the old configure script.
I've patched the cgiutils.h, but now compiling fails of some missing #ifdefs,
so ive fixed all the missing #ifdef 's.
Please apply the patch to fix those problems ...
Best regards
Percy Jahn
BTW: There is still the problem with Hostchecks that can't be parallized. If
many Host go down, nagios gets stucked in Hostchecking. Especially if many
passive checks are used, Nagios won't process commands written into the
command pipe. Is there some work on the way for version 3?
Content-Type: application/octet-stream
filename="autoconf.patch"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=
Content
...[email truncated]...
