> Hi all,
> as mentioned in Ethans Thread for testing the actual branch version, I
> am afraid the problems are not only sitting on the buffers.
> I have talked to a collegue of mine, watching to the sources. Specially
> the event.c on line 1079
> if(run_event==TRUE){
> /* remove the first event from the
> timing loop */
> temp_event=event_list_low;
> event_list_low=event_list_low->next;
> /* handle the event */
> handle_timed_event(temp_event);
> // This is 1079 -----------^
> /* reschedule the event if necessary */
> if(temp_event->recurring==TRUE)
> reschedule_event(temp_event,&event_list_low);
> /* else free memory associated with the
> event */
> else
> free(temp_event);
> The function starts after on line 1154 and following.
> If I am right, this is the worker part who do anything for nagios,
> starts checks, get check result (reaper), freshness checks and anything
> else.
> Is this part working serialized (one shot after another) or is it
> threaded before?
> If it is serialzed, won't it be able to paralize it?
> Do anyone know how long the processing of handle_timed_event is running?
> (Just a question before, I will test it after this mail compiling with
> debug3)
> Just a my 2 cents.
> Best wishes
> Hendrik
[snip]
Most things in Nagios are performed in a serial fashion. They include,
event handlers, starting service checks, running the OCSP command,
updating the status log, etc. All these actions are kicked off the the
handle_timed_event() function, which runs each thing serially.
Although the process of starting service checks is handled serially, the
actual execution is run in parallel, and the service check reaper (which
collects service check results) runs as its own thread. The processing
of service check results is handled in a serial fashion, although this
is not a time-intensive process like the actual execution of a check.
The execution of host checks are the huge holdup in Nagios 2.x, and they
are (for the most part) parallelized in Nagios 3.x, so that will help in
the future. Things like event handlers, notifications, etc. are hard to
run in parallel while ensuring that certain things happen in a
particular, repeatable order.
Hope that helps. It can get more confusing the more you look into
things.
Ethan Galstad,
Nagios Developer
Email: [email protected]
