------=_Part_11157_26717126.1175611144035
Content-Disposition: inline
On 4/2/07, Hendrik B=E4cker wrote:
> > recurring Scheduled Downtime skews Nagios' Availability report.
> > It's my understanding that Nagios won't check the host or service if
> > it is in scheduled downtime. Is this incorrect?
> No. Nagios checks it but don't notify you while in a downtime.
> You have to evaluate the downtimes for you Avail Reports... I don't
> know exactly what Nagios will do, in first case it might be that
> Nagios will show downtimes as downtimes (cause they are downtimes) or
> it ignores downtimes cause it would be no break down if you now that
> it would happen.... I am not sure.
We have up-time requirements that must be met. A host has a scheduled
downtime for 2 hours but will only be down for 5 minutes somewhere in that =
2
hour period. This is not 2 hours of down time and our availability report
would get me fired if it said the host was down for 2 hours every day.
There must be a way to do this. If not, then it's an important feature to
consider. No?
-David
Content-Type: text/html; charset=ISO-8859-1
On 4/2/07, Hendrik B=E4cker <=
[email protected]> wrote:
> recurring Scheduled Downtime skews Nagios' Availability report.> It's my understanding that Nagios won't check the host or ser=
vice if> it is in scheduled downtime. Is this incorrect?No. Nagi=
You have to evaluate the downtimes for you Avail Reports... I don't=
know exactly what Nagios will do, in first case it might be thatNag=
ios will show downtimes as downtimes (cause they are downtimes) orit ig=
it would happen.... I am not sure.We have up-time=
requirements that must be met. A host has a scheduled downtime for 2 hours=
but will only be down for 5 minutes somewhere in that 2 hour period. This =
is not 2 hours of down time and our availability report would get me fired =
There must be a way to do this. If not, then it's an important =
feature to consider. No?-David
------=_Part_11157_26717126.1175611144035--
