According to 'current' nagios documentation for host definition
(http://nagios.sourceforge.net/docs/3_0/ ... tions.html),
there are few required directives. Those directives are:
- host_name
- alias
- address
- max_check_attempts
- check_period
- contacts
- contact_groups
- notification_interval
- notification_period
NOTE: address is not really required according to Note under=20
descriptions
for host definition, but still listed (red) ... and so=20
required?/confusing?
NOTE2: Either contacts or contact_groups must be defined, both do not=20
have to
be defined
This however does not appear to be correctly/fully validated. Example=20
of
invalid host definitions that pass validation without errors:
max_check_attempts 5
contact_groups router-admins
# This will warns there are no contacts specified
# maybe it should raise Error?
host_name bogus-router
From above, only max_check_attempts and contact/contact_groups are
validated. Following additional directives are never checked but should=20
be:
- host_name
- alias
- check_period
Similar applies to service definition. List of required directives=20
according
to docs:
- host_name
- service_description
- check_command
- check_interval
- retry_interval
- check_period
- contacts
- contact_groups
However, one can use following service definitions and they pass as=20
valid:
host_name test-host
host_name test-host
check_command check-host-up
host_name test-host
service_description Ping
max_check_attempts 2
Without check_command directive validation alerts with:
"Error: Service description, host name, or check command is NULL"
Without max_check_attempts following error message is shown:
"Error: Invalid max_attempts, check_interval, retry_interval, or=20
notification_interval value for service ..."
But the messages do not apply to each and every directive they mention,
specifying just one makes the error go away (though I have not done=20
every
possible iteration for each).
It is possible that other required object directives are not validated,=20
but
this was not tested.
Some of the above examples are not that bad, nagios ends up ignoreing=20
those
invalid definitions. For example host definition with no directives or=20
with
only max_check_attempts directive does nothing. But other definitions,=20
last
host definition and last service definition for example (granted=20
host_name and
contact_groups used there are defined), result in never ending:
"Caught SIGSEGV, shutting down..."
message in nagios.log.
Is anyone else experiencing these problems or am I missing something=20
obvious?
-Peter=20
