Re: [Nagios-devel] Solaris packing build...
On 11/12/2010 04:09 PM, lists wrote:
> Good point about gmake, I did have a lot of problems with make so
> wrote my doc for gmake.
> I tend to do something like:
> http://s23.org/wiki/Nagios/build/Solaris
> I have not updated version numbers in that doc so that might not quite work!
Do you really need gcc to make it compile? I was under the impression
that Nagios would work fairly well with any C90-compatible compiler,
so long as libc on the system has the BSD4.1 stuff we need.
OP5 AB www.op5.se
on peace.
