Monitoring 15000 Interfaces / 300 Routers
hrnaqvi
Post by hrnaqvi »
Dear Team,
I am monitoring 15000 interfaces of 300 routers, the issue I am facing is low performance and polling interval.
Version of my Nagios XI is, (Nagios XI 2011R1)
Nagios performance is quite slow in monitoring 15000 interfaces of 300 routers, I am monitoring bandwidth utilization and port status.
When one polling starts, Nagios does not complete to collect the data in 5 minutes, meanwhile the second polling interval starts.
That means one polling data is not received with in FIVE minutes and second polling starts.
I hope you get my query.
Regards,
Hasnain Naqvi
rdedon
Re: Monitoring 15000 Interfaces / 300 Routers
Post by rdedon »
Hello Hasnain,
what type of setup do you have Nagios XI installed on (VM, stand-alone server, etc) and with how much resources dedicated (memory, drive, etc)?
Thank you.
Rene deDon
Technical Team
___
Nagios Enterprises, LLC
Web: http://www.nagios.com
hrnaqvi
Post by hrnaqvi »
We have Nagios installed on VM machine dedicated memory is 4 GB.
rdedon
Post by rdedon »
Okay. Could you try optimizing your Nagios XI server by following the instructions with this document:
http://assets.nagios.com/downloads/nagi ... rmance.pdf
Several people have found that this greatly improves performance on bigger setups, so this should help.
Could you respond with results when possible?
Thanks!
Rene deDon
Technical Team
___
