------=_NextPart_000_00EC_01C6A1CE.BA2E28C0
Content-Type: text/plain;
charset="us-ascii"
Excellent, it works! Thanks for fixing it that fast!
Since we're at it, I'm wondering if you're willing to look at the command
file processing code. I reported some time ago that Nagios were randomly
skipping some passive checks since I set up around 60 hosts to report trough
nsca (Using a tcpwarper) at the same time. Andreas Ericsson replied it was
due to the pipe filling up, which I hardly doubt. From my testing the pipe
start to block at around 1000-1500 passive checks results sent at the same
time, and even if it blocks it shouldn't miss any check (am I wrong on that
assumption?).
If I set max_check_attempts to 1 I get a page every 2-3 hours on average.
Thanks again,
Thomas
> -----Original Message-----
> From: Ethan Galstad [mailto:[email protected]]
> Sent: July 6, 2006 16:58
> To: [email protected]
> Cc: Thomas Guyot-Sionnest
> Subject: Re: [Nagios-devel] Segfault during pre-flight check
> Thomas, et al -
> I think I've found and fixed this bug. I just posted a
> proposed fix to
> CVS a few moments ago. A new CVS snapshot should be
> available in about
> 10 minutes from the following URL:
> http://nagios.sourceforge.net/download/cvs/
> When you get a chance, can you grab the latest nagios-2-x-cvs
> tarball,
> compile it, and see if it fixes the segfault? Thanks!
> Thomas Guyot-Sionnest wrote:
> > Hi,
> > I'm maintaining a pretty big nagios setup (about 60 hosts/
> 600 services and
> > plan to grow that by 3-4 times). Most of the config is
> using templates to
> > save config lines and maintenance time. Every host has an
> extinfo (one
> > definition for each hostsgroup).
> > Now I started adding services extinfos to do some fancy
> things with e-mail
> > pages, and ran in a strange segfault bug. To explain it
> better I'll give an
> > overview of my config.
> > templates.cfg: This defines all basic hosts, services and
> service extinfo
> > templates.
> > Ex:
> > define service {
> > name generic_service
> > max_check_attempts 3
> > normal_check_interval 300
> > retry_check_interval 60
> > check_period 24x7
> > notification_interval 600
> > notification_period 24x7
> > notification_options c,w,r
> > contact_groups admin
> > register 0
> > define service {
> > hostgroup_name admin,license,public,web
> > use generic_service
> > name dynamic_service
> > register 0
> > services.cfg: This defines services based on template above.
> > For ex.:
> > define service {
> > host_name nagios.example.com
> > service_description HTTP
> > servicegroups http_svc
> > check_command check_http!$HOSTADDRESS$
> > use dynamic_service
> > Will add this services for all hosts in hostsgroups
> > PLUS host nagios.example.com
> > So far this works fine. Now I add in templates.cfg (Note
> that I removed the
> > ampersand from "illegal_macro_output_chars" for this to work) :
> > define serviceextinfo {
> > name generic_service_ext
> > action_url
> https://nagios.example.com/cgi-bin/exti ... 2&host=$HO
> STNAME$&servic
> > e=$SERVICEDESC$
> > register 0
> > use generic_service_ext
> > name dynamic_service_ext
> > register 0
> > And in services.cfg:
> > use dynamic_service_ext
> > Then run:
> > # nagios -v /etc/nagios/nagios.cfg
> > Nagios 2.4
> > Copyright (c) 1999-2006 Ethan Galstad (http://www.nagios.org)
> > Last Modified: 05-31-2006
> > License: GPL
> > Reading configuration data...
> > Segment
...[email truncated]...
