Re: [Nagios-devel] Nagios2JSON
I coded the XSDJSON, and it wrote now the status.dat directly in JSON
format.
I have problems with read_status_data function, if anyone could have a =
look
on the file http://www.intelunix.fr/xsdjson/
-----Message d'origine-----
De=A0: [email protected]
[mailto:[email protected]] De la part de Tom
Throckmorton
Envoy=E9=A0: vendredi 13 juin 2008 18:58
=C0=A0: Nagios Developers List
Objet=A0: Re: [Nagios-devel] Nagios2JSON
On Jun 13 18:06, Yann JOUANIN wrote:
> Ok, I seems to be a good idea, I will start coding it next week.
> Other suggestions are welcome.
Excellent work! When you do get to adding filters, would you consider
making
the output compatible with the OpenSearch suggestion format? That would
make
it trivial to support a Nagios search extension for browsers that =
support
this
standard (currently Firefox 2.x & IE7) For reference, see:
http://www.opensearch.org/Specification ... uggestion=
s/1
.0
http://developer.mozilla.org/en/docs/Su ... ns_in_sea=
rch
_plugins
Cheers,
-tt
Check out the new SourceForge.net Marketplace.
It's the best place to buy or sell services for
just about anything Open Source.
http://sourceforge.net/services/buy/index.php
_______________________________________________
Nagios-devel mailing list
[email protected]
https://lists.sourceforge.net/lists/lis ... gios-devel
